robby forest
i have installed a 13 gal holding tank under the starboard settee, i got 3 different tanks from a local supplier and it fit the best. i drilled two 1.75 holes next to the original water line holes. i plan to run a 4' hose from the toilet to the upper fitting on the tank. i plan to run a 5.6' hose through the under side of the cabinet through one of holes that the original vented u pipe ran through up behind the sliding lavatory doors to the deck to a pump out fitting. this route seems to more or less hide everything. i'm not sure what type of vent i need. but a more pressing concern is if i pull the hose off will the gate valve hold the water out? should i stick a rag in the through hull? the water here is kiinda cold. Does the barb screw of the gate valve and can i put a pipe plug in the hole or is it made on and if so will an expandable freeze plug work in fresh water. or do i need to pull the boat and put a through hull with a plug in it in? any comments would be appreciated i'm not rich i saved a year to buy the boat and i don't want to lose her.
