install air conditioner
Aug 28, 2015
2
beneteau frisr 345 flowery branch
Has anyone ever installed and air conditioner on a Beneteau 345 ,1985 '
Aug 28, 2015
2
Thanks, that would be nice to see where you put it and how you ran the vents
Rick
MitchM
Jan 20, 2005
1,031
another a/ c location issue is: be sure to leave enough access room around the march or other below-waterline raw water feed pump so you can loosen the screws on the pump head with a screw driver to winterize the pump. and to add an air bleed line between pump and compressor....
Likes: stevemitchell
