Here is a basic question.
What is required and how dificult is it to:
1. Run wire through the mast while the mast is down?
2. Run the wire to the instrument panel?
3. Should you run the wire from the panel to the place where is will be connected when the mast is about to be stepped?
4. and then on to the pedistal?
I have never done that type of work and running from the bottom of the mast on to the instrumental panel seems like that would be pretty dificult.
Please comment on what to look out for when doing this type of work on a Hunter 30.
Thanks,
Steve
Thanks,
Steve
