Move the pump!
Why try to work on 1 and 1/2 inch hose and pumps through that hatch. It's always going to be a nightmare. My solution was to move the pump to that shelf area on the starboard side of the "footwell" of the V-berth. Nice, easy to inspect area and no worries if I have to change the pump. I also went with the big solids pump for about twice the cost of a macerator and a dead solid, rebuildable pump. The third mod I'd recommend is a y-valve inside that little access door to isolate the overboard discharge and pump from the deck pumpout. eliminates a lot of mess if maintenance is necessary when the tank is full. Come to think of it , that's when you find out that maintenance IS necessary any way!Enjoy the job and use lots of bleach in the tank first, and lots of Joy on those stiff hose fittings!S/V Jazz 1984 H31 #329
