O'Day 34 inner forestay
Jim, I have the original manual for the 35 and the sales brochure and it doesn't mention it as an option. You can have a boatyard do just about anything you want though.Some things to be concerned with, The Isomat mast does not have a place for an extra headstay (uses stemball fittings with spherical cups in spherical holes). So to add a headstay you will need some major mast surgery. Secondly this should not be supported only by the deck, Rigging loads are high and should be carried by the hull itself or as in our boats by the liner bonded to the hull and the main structural bulkhead. To do this in you v berth will certainly mess up your berth. Plus directly under where you want the support is your holding tank. So you could remove that, bond in an attachment point for a rod, run a rod up through the v-berth to dech level then as on your shrouds drill for a u-bolt through the deck.I really like cutter rigs and wish I had one but this modification looks pretty extreme. I would leave it alone anf if you really want a cutter, seel the O'day and get a cape dory or maybe an island packet or pacific seacraft ( i think those have cutter tigs but not sure), get out your wallet for any of the above.if you find out more let me know.dave
