injector change
257
- - long island,ny
I have an Oceanis 321 with Volvo-Penta engine type MD-2030. I have to replace the injector nozzles after 1000 hr. I didn't know it should be changed, at periodic check of engine, we have noticed that the movement of needle in injectors ( all of 3 ) are almost impossiblle, they move in and out very hard and we decided to replace them. Is it normal to change them at 1000 hour, or do I missing some items related with engine. Thank you.
Jun 1, 2004
227
Beneteau 393 Newport
They don't need to be changed.
They need to be tested and rebuilt. Only the nozzle wears, generally, in a mere 1000 hours. The major reason for failure in so short a period would be clogging from dirty fuel or excessive wear of the orfices. Whatever you do, don't clean them. They must be serviced by a certified shop. Jim
