Injection Pump Timing
Oct 30, 2019
106
I may have asked this question once before, but forgot the answer.
I would like to check the injector timing on my MD6b. The shop
manual says to:
Turn over the engine until the valves in cylinder
No. 2 "rock'. Continue to turn over the engine in
the normal direction of rotation until marking 10
on flywheel coincides with the marking on the
block.
Ok, I found the mark "10" on the fly wheel. I do not see the mark on
the block. Could someone please let me know where it is.
Thanks
Paul
V2926
Oct 30, 2019
36
It is in the manual..but it is right up front and center on the block just
above the flywheel. I used a carpenters square to align it with the mark on
the flywheel. Try putting the square on the block and moving the mark so it
is dead center above the crank. The mark may be covered with paint but you
should be able to find it.
Richard Pellegrino
Staff Engineer
