InHull transducer; more problems?
Apr 19, 2011
456
Hunter 31 Seattle
Hello,
I'm currently faced with the challenge of getting new transducers in the boat for my Garmin 740s chartplotter and my factory depth gauge.
I was going to get the In-Hull transducers and actually bought some but I've talked to some friends that say they are more problems then they are worth. Specifically they leak the fluid inside of them and stop working. Should I scratch my current plans and get the "normal" thru-hull transducers?
Thanks so much!
-Jared
May 29, 2011
116
Hunter H 240 rehoboth beach , De
transducers
My experience with in-hull transducer[depth] is positive. If they leak, it is because they were not installed properly.
They are trouble free if you install it correctly.
HMT2
Mar 20, 2014
900
Hunter 31 828 Shoreacres, TX
Hello,
Thanks so much!
-Jared
I have the "shoot through the hull" transducer for my Garmin 541s. I have had it in place for about two years and have had to add fluid once. When it is low the depth reading flashes because it can't get a good read. I put some Vaseline on the lip that seals the transducer in when I refilled it and it has been fine. Be sure and do the baggie full of water trick in the directions to find a good place to put the transducer.
I am happy with it, and it is one less hole in my boat that water can come through!
Jan 4, 2006
7,161
I don't get it here. The later depth transducers are a potted plastic puck that are just "glued" to the hull and transmit and receive right through the (ideally) solid, uncored hull. There is no need for an fluids. I know that some of the early in hull transducers were suspended in a bath of liquid, but I've still got to question if this was even necessary.
Anyone have any information on early in hull transducers ?
HMT2
Mar 20, 2014
900
No sir, my two year old transducer from Garmin has a small hollow puck that you glue to the solid part of your hull, you then fill it with a fluid, and twist on the transducer into the fluid filled puck. They recommend an antifreeze (see link below) it does not work with out it. When testing the best place to put your transducer you fill a ziploc with water, put your transducer in the ziploc and place against your hull in the areas you want to put it. No fluid, no reading. Here is a link to the fluid I use.
http://www.westmarine.com/seafit---50-f-marine-rv-antifreeze--P014823330
Aug 18, 2013
1
laser 13 valparaiso
I replace mine (in hull) transducer and I use the old installation (kind of plastic cilinder with a cap glued to the hull and filled with oil) and work ok. I suspect the oil is old as the boat (20 years).
