Now I understand...
Dec.8, 2000Dear Dave,Now I understand, and your right a diagram would be really helpful, so once again I suggest a trip to your local library to look at the basic sailing books that cover reefing to find what you need. Any of the good basic learn to sail books should cover this.Now let me try to give you a verbal description, keeping in mind that your actual application may vary depending on where your hardware is located and what type you have .What you really need to know is where the jiffy reefing line goes. On our boat and on most boats I have seen there is an individual jiffy reefing line for each set of reef points. Our boat has three and your boat likely will have two lines of reef points in the sail.Here's what you do:Lay out the sail to see how many lines of reef points you have and thus determine the number of jiffy reefing lines you will use. Put the sail on the mast and boom and raise it, mainsheet eased. Starting with the lowest set of reef points (the first reef) attach the jiffy reefing line onto the fitting provided for it at the end of the boom on either the port or starboard side. Make sure you use the reefing cringle on the leech and not the outhaul cringle on the foot of the sail. Reeve the line from the boom up through the aft most reefing cringle on the leech of the sail, back down the other side of the sail to another fitting on the boom, hopefully a turning block . On our Beneteau the reefing lines actually runs through the end of the boom on a turning block forward to a rope clutch on the underside of the boom. I don't know if yours is like that , so read on in case it has this alternative rigging. From the turning block the line runs forward on the outside of the boom to a second turning block, back up through a luff reefing cringle at the front of the sail, back down the other side to a cleat on the boom for belaying the line. Thus in summary you have a line running from the back of the boom, up through a cringle on the leach of the sail, back down to the boom on the other side, then forward to a turning block, back up the cringle at the luff or forward part of the sail and back down to the boom on what would now be the same side as the line started out on. You may try drawing this yourself for clarification. Needless to say actual applications may vary from this description. You will have one of these line for each set of reefing points.As I mentioned earlier our Beneteau has the reefing lines running through the boom to a set of rope clutches. This is in fact only a partial jiffy reefing as the full system requires the line to go back up through the front of the sail which our system does not do. However it also is not necessary, since the sail lowers easily and I have to be forward at the mast to loer the sail and to put the tack cringle on the pig tail (also called the tack fitting). On later developments of the full jiffy system I have described instead of belaying the line on the boom the line is often lead further down the mast and back to the cockpit, the thinking being that it is safer to never leave the cockpit. But then how does one secure the tack to the pig tail? Leaving the sail held down by the jiffy reefing line is an invitation to chaffing and the ultimate destruction of the line.Dave, I really appreciate your dilemma. On my very first boat ever I put the mainsail on upside down (foot up the mast) and ran every single line incorrectly before finally getting it all sorted out, I thought. Launched and ready to go on our first sail an old shellback came by, looked the boat over and in casual conversation noted, "Interesting how you rigged the boomvang. It will still work like that, but I usually put mine on the otherway round." He was too kind to simply say we had it rigged backwards!So hoist a glass and drink a toast: "To Trial and Error" when your done, and who knows you may even get a funny anecdote out of the experience. Good luck on sorting it all out.Brian Pickton@BeneteauOwners.netAboard the Legend, Rodney Bay, St. Lucia
