Tender 23.5 (my two cents)
Heed the advice of these wiser heads and reef early! Even though I sail one of the older, stiffer H23's with the wing keel, I still reef early. As a matter of fact, I often put a reef in before I leave the dock, because it's easier to do it there than out on the water with the wind howling and the sails flapping like mad. If the wind slackens when I am out, it's easy enough to shake the reef back out.Sailing is supposed to be fun, and relaxing in the cockpit is more fun than climbing out onto the rail with the tiller extension fully extended. That's why my dinghy is now sitting on its trailer in my backyard. I also learned that reefing can actually make the boat go faster. Apparently, excessive heel creates more drag because of the greater wetted surface, more weather helm and drag from the rudder trying to keep the boat from rounding up. Give it a try and see. If you have a knotmeter or a GPS it should be easy enough to verify, also less heel will keep your crew happy (very important!!).Here's another hint. You can reduce the amount of heel by raising your centerboard slightly (about a quarter to a third of the way up). You will have more sideslip (boat drifting to leeward) unless you bear off a bit, but you will have a more comfortable and controllable ride. Besides, being slightly off the wind can gain you some boatspeed , and can help compensate a bit for the reduced ability to point high. Happy sailing!Peter Suah "Raven"
