Low cost - Low weight
We went with the low cost rollup from west marine. They are made by Zodiac. At only 39lbs it's easy to deflate and stow below, and man handle over the side, eliminating the expense of davits. The negative is that it's PVC and not made of the more durable hype-a-lot. If you can afford it then go with the better quality, but for the $1495 package deal that W.Marine had for the dingy and a 5hp motor, we couldn't even find a used one that came close. They even threw in a cover! Scott83-H34 Island Hops.PS. Be it top of the line or bottom of the rack. They will all last with proper care and maintenance.
