E
Ed
I'm sure someone out there with a 23.5 has expeienced this. 15-20 kts, 4 ft+ waves. Problem is with water in the normally dry bilge. I found one leak with the sink drain, no problem fixing that. What does one do with water backing down the through hull to the bilge pump? I don't think putting a 4" loop in the line will resolve the problem which is all the room there is under the sink. A seacock? Maybe a check valve? It's a real pain mopping up after an afternoon sail especially if you store anything under the seats in the cabin.
