I have an H-27 and have been storing it in a year for years. It now costs $1,800 per winter plus a $250 power fall wash down (mandatory) .....
HN
I have been towing my H22 for a few years now. Each fall and spring the marina uses the travel lift to load/unload the boat from the trailer, though half the weight and 5' shorter, it has given me some experience. I am faced with similar costs for winter storage, though my main reason for hauling the boat home is to work on her. It is a 2 hour round trip to the marina. A 2 minute walk out back. The oversize permit will cost 55.00 for CT and RI combined. The trailer will wnd up costing 1200-1600. I have a friend with a 1 ton dually truck. Mast step/unstep is 130 each time. I figure that the first season I will break even.
Karl,Here are the measurements of the trailer I have for my 1980 Hunter 27.
Width = 80 inches
Length = 142 inches
Corners of the trailer are reinforced both top and bottom with 1/4" steel plates
Tongue Length = 92 inches (Meaured from the front of the frame to the tip if the 2.5 inch ball hitch)
Tires = 8-14 Goodyear Light Truck
Box Frame is 2" x 4" tubing
Tongue is 4" x 4" tubing double stacked to minimize flex. Tongue is extended at approximately a 35 degree angle to each side of the trailer as it reaches the frame.
Pictures to follow when my camera thaws out. Minus 28 degrees with the wind chill today.
Axles and wheels were purchased used from a mobile home mover. Originally were used on a 12' x 40' mobile home. Should be easy enough to locate same in your area.
Front wheels of trailer are equipped with electric brakes.
Thanks Ed I'll give it a try that way, I'm certainly not the swiftest individual when it comes to the old computer. Minus 26 here today with the wind chill and a not time to be out in the boat sanding or removing the teak to refinish it. We're doing some upgrades over the winter, new propane stove (Dickinson) and refinishing all the wood work and replacing the counter and chart & dinette table tops before putting Break Away up for sale. Hoping to find a good 37.6 Legend by spring. 15 months now till I pull the pin.What is your issue on posting of photos Karl? Do you have them loaded on your PC from the camera? I don't think you can load them here from "Quick Reply". If you click on the "Post Reply" box as I just did then below this text entry box you will see a "Upload Photos or Files Here" box. Click on that and find and select your photos from the "Browse" boxes. Then do "Upload" and they should load. There is no real indication that they are finished loading other than seeing the files and sizes in the little load box. Close that box and then "Submit Reply". Hope that helps.
