In-mast roller furling continuous line
Jan 29, 2010
64
Hunter 38 Ocean Gate, NJ
One of my winter projects this year is to change the continuous line on the in-mast roller furling mail sail of my 2006 H38. Has anyone done this? Any problems to be aware of or tricks to know? I should have done it a couple of weeks ago during the super-warm stretch the northeast had...
Have a safe and Happy New Year on and off the water!
meb135
Nov 17, 2012
92
Hunter 33 Shediac Bay
I've replaced mine. There are plenty of good YouTube videos that will show you how to splice a continuous line. Make sure you have the proper size fid. a very important tip would be to make sure you absolutely keep your line from twisting when you are splicing. Otherwise, your line will get knotted up when it's running through the clutch.
It's actually a fun little project.
Marc
Dec 29, 2009
149
Hunter 380 Little Creek, Virginia Beach, VA
I replaced mine this year. Concur w/Marc...a fun project, and plenty of guidance available on continuous splicing. Of course it has to be done "in situ", so good weather is real plus.
May 16, 2007
1,509
Boatless ! 26 Ottawa, Ontario
I found stitching the splice keeps things tight. We had a rigger do ours, he had to come back after we used it a few times. He did it over again and stitched it, since then no problems.
Bob
Sep 20, 2006
2,952
If you've never spliced before, I suggest practicing on a short piece before doing the furling line on the boat. If you get it wrong and have to cut the line to start again it may end up too short, ask me how I know this, but luckily I had bought a slightly longer line than needed.... Definitely stitch the splice to keep it secure.
Also, as above, there's lots of good Youtube videos on splicing.
