I'm questioning the in-mast sail ,verses the boom furler and the "old" fashioned way of dropping the main sail. My thoughts were open and the in-mast sail being somewhat new, ten yrs old or so, and being readily available and seemingly popular, I have to look into this somewhat "new" technology in sailing. There's not a lot of experience with these units, never mind well worn main sails out there. I have come up with the conclusion, reading about the nightmares of the in-mast main becoming jammed and if it's not done just so (with the wind blowing from the starboard side and holding a line in one hand and pulling the other line with the other, while letting one gently slip out, while sailing on a particular point of sail) you are, in for a nightmare. Way to many details that if you don't follow, you are in for the nightmare of your life.
There seems to be way to many details to do in a certain order, at a certain time, with the wind blowing in certain direction. While I have never sailed with the in-mast, I can see one of my favorite points of sail is not advised, wing to wing sailing. Can't do it with the in-mast B&R rig. I have been reading several sites and those with worn sails that are somewhat stretched in the center, are having problems if the sail is not massaged into the mast, so it will be able to furl out OK. Massage in and massage out. Just what I want to do is massage the main sail in and out. I just drop it and bungee cord the thing out of my line of site and don't miss a beat. Sailing I do for relaxation, not having to think about a thing, never mind how I'm going to furl and unfurl the main and be sure to do it in proper sequence, or there will be hell to pay. Am I way out there making something out of nothing? In the long run (10 to 15 yrs) is the in-mast really worth it? I can see the advantages and it seems the disadvantage far out weigh the advantage. Screw up one step in the sequence and your main stays 3/4 up/out and catching wind. What are you going to do then? Anyone care to discuss the pros and the cons of in-mast main sails? Many pros, but the one con is a biggie. Thanks
Keep it up,
Ctskip
Keep it up,
Ctskip
