That's a Good Item of Concern
As is typical with a new technology there can be some growing pains and jambing furlers is an item that has been talked about. The question is, are the new furler designs sufficiently trouble free? I can't answer that, but, here are a couple items on other furler related subjects:1. Wiring: In the boatyard was a new mast with a Seldon furler, or it may have been a Seldon mast, I don't know. It was for a relatively large boat, say 48 ft or so. The motor drive for the furler was midway up the mast and the conductors were a large gauge (#2 or #1?) and un-tinned. Untinned wire does not meet marine grade standards because it will corrode, become brittle, and have increased resistance. If you go with a furling main I'd highly recommend the use of tinned conductors on this important item.2. A furling main, talking about in mast furling main, is not very fast because it has no battens or roach. Additionally, when reefed the center of gravity does not lower like a slab-reefed system or in boom reefing system.My boat has slab reefing and the boom is close enough to the deck that it is a good handhold when trying to flake the main in rough water.Hope this helps and maybe it will spark some discussion.
