In Mast Furling
I have a 1999 h380 w/In Mast Furling. I can think of arguments for the system and against it. If your plan is to only use your boat for cruising/daysails, you can't beat the ability to put away the sail and get on to the more serious partying fun. If your plan is to race your boat occasionally, you might find yourself frustrated with the lack of sail shape you'll need to keep up with boats that have things like; battens, and a main with a full roach,(negetive roach on roller systems = smaller sail area).If you go with the roller system, the very first thing I would want if I ever do it over again, is to have the dealer give me a credit for the sails that come with the boat and have a local sailmaker actually measure the rig and build a sail that fits. Those Chinese UK sails are not always quite right. My main sail is OK, however my friend has a h410 with the same system, and his OEM sail looks like a bad load of laundry hanging out in the wind with all the wrinkles. He's had it recut and it still looks bad. I almost forgot one of the best things about the roller system, when it comes time to reef the sail, it's excellent! Just roll it in a little or a little more.Hope this helps,Rick
