Why furl on a 29?
I have a 460 with an in-mast furler and single-hand or often have few or inexperienced crew. I like the furling main because I can handle the large main on the 460 by myself. My experience with older large boats without any sail handling equipment (w/o furling, lazy jacks, etc.) is that you need good crew. The boat goes plenty fast (for a sailboat) even with a furling main.The 290 is a much smaller boat and has a much smaller main - you may be able to manage smaller sail area dependent on your abilities and the abilities of your potential / regular crew. If you want the extra power, and you have confidence in you or your crew's ability to manage the main on the boat you are looking at, go for the battened sail - it's not that much work. If you decide that ease of use is more important, the furling setup is definately the way to go.Regarding safety of the two alternatives, as far as I am concerned, as long as you maintain and operate furling gear (and aevery other system) correctly, you should not have any problems with the furling setup.
