E
Ed
I am going to ask this question again in a little different way to solicit some different answers. I have in-mast furling on my 426. When do you need to use the ratchet? I have always used it when furling the sail (different boat) - answers to a previous question about having to go forward to set the ratchet and the potential problems this has in heavy seas garnered the concensis that you don't need to use it and that the tention on the furling drum is enough to keep the sail from playing back out - is this the case? Seems like a lot of tention on a line that has only 1/2 of a wrap on a smooth drum, especially if the wind is 30 - 40 knots?If this is the case when do you use the ratchet mechanism - if ever? Thanks for any enlightenment on this issue. Currently I use it when reefing - but if it isn't nessasary I won't bother - the problem I am having is that "it is there" which makes the engineer in me think it is there for a reason. Ed
