In-Mast Furling Outhaul replacement line
May 22, 2017
42
Catalina 310 17 Lake Carlyle
My 2000 year 310 with in-mast furling needs the Outhaul line replaced. I'd like to buy one this winter (boat is winterized) for a spring time replacement.
My owners manual doesn't give me the length or size. (minimum shrinkage) I imagine this has been done before so someone has measured and replaced one.
Frank Hines
Lake Carlyle, Ill.
No Tippy Hull #17
Feb 21, 2013
4,638
Hunter 46 Point Richmond, CA
What you can do is sew a tag line to the end of the outhaul line and pull it through then measure it and order it on line OR take it to a rigging shop to make up a new one.
KZW
May 17, 2014
831
Catalina 310 #307 Bluewater Bay, FL
Catalina Direct says 5/16, 70 ft. But I don't know if that is for the Genoa or Main.
I replaced my main outhaul in 2015. I measured the line that was available, counted the turns on the spindle and multiplied (pi*diameter) to come up with total length. What I failed to do was record the length. I used Sta-Set and it was $104 at West Marine.
Aug 29, 2016
135
Catalina 2004 310 (Hull #250) BC
I just replaced some of my running rigging 6 months ago and here's my list:
  1. Genoa sheets (2) Samson XLS3 10mm 50’
  2. Spinnaker sheets (2) Samson XLS3 10mm 60’
  3. Main halyard Samson Warp Speed II 3/8” 115’
  4. Main sheet Samson Warp Speed II 7/16” 100’ (or was it 75’?)
  5. Main inhaul Samson Warp Speed II 3/8” 62’
  6. Main outhaul Samson Warp Speed II 7/16” 52’
  7. Jib furling line is 3/8”? 67’ long
