Hope there's not a limit on questions but I just really want to learn.
Looking at my boom I've found that it contains three lines. The one in the center is the outhaul. The other two I believe must be reefing lines. I'm guessing that one is for the first reef clew point and the other would be for the second reef clew point. Does this make sense?
I assume I could assign either the port of starboard line to either reef point.
boomendbottom2 by picndicular, on Flickr
Here's a photo of the exit hole and cam cleat for the reefing line.
portboomcamcleaat by picndicular, on Flickr
Besides the line looking like it's not really caught in the cam, does this look like it's set up correctly? Do I need to cleat the line off after this cam as well? The cam seems to hold the line good as it is.
and finally to make this more convoluted...
I'm wondering what these hooks are for that are on both sides of the gooseneck. I thought that they were for running the reef tack through for a real quick hookup but the sail slides bunch up too much to pull the sail down to where the reef tack can hook onto. Cunningham hook?
porttackhook by picndicular, on Flickr
Thanks again
Thanks again
