Rob
Ah - where to start....After an afternoon sail today, I did a routine check on my bilge pump (1 year old) and found it was not functioning. Luckily, my bilge is relatively dry (I have an A-4) and I rarely, if ever, see it pump out. Nonetheless, I like to know that the pump is up to its task, so I dump a bucket of water into the bilge once a month or so, and watch the pump go at it. Today, it failed completely. I am writing this post to warn you of a possible problem that may exist on your boat if you have my type of pump.The pump in question is a Rule 500 Platinum. It is a self contained unit, which does not use a float switch. It operates by spinning up once every 10 minutes. If the impeller senses no resistance, it cycles off, and waits another 10 minutes before checking again. If it DOES sense resistance, which it assumes is water, it runs until the water is pumped out and no water is left to offer resistance. It then goes into alert mode, cycling every 2 minutes for the next 10 cycles, and then returning to cycling every 10 minutes. A sound principal in theory, but here is its Achilles heel.If water enters the boat somewhat suddenly (such as a broken hose), an air bubble can (and frequently does) form around the impellar, causing the impeller, when it spins, to spin in air, not water. In other words, the bubble keeps the water away from the impeller, and the processor on the bilge pump senses no resistance, which SHUTS THE PUMP DOWN AS WATER CONTINUES TO FILL THE BILGE.I know this sounds a little alarmist, so I performed a test. I disconnected the pump from the battery, and reconnected it to force it to start cycling. I did this over 20 times without the pump drawing water (even though it was completely submerged). Doing a rough calculation based on the pumps cycle times revealed that the boat would have taken on water for almost an hour - and at the end of the test, the pump still was not pushing water out of the boat.I am of the opinion that this type of pump has a design problem. Has anyone else experienced this?As always, your opinions and experiences are greatly appreciated.Best Regards, Rob Rich
