Not important that ya find the part.. it is really important that you know that you have un-impeded flow. Almost the same problem.. I would have suspected that the blade would have been in the inlet side of the heat exchanger,covering a couple of tubes. If you are sure it is not there, then pull the outlet cover and check there .. if it is not in the outlet side cover then look thru each tube to see if it is in one of 'em.. or get a pistol cleaning kit and brush the interior of each tube .. something like a 30 caliber brass bore brush is fine.. The tubes are 5mm ID by 6mm OD.. There arre 24 of 'em; it is three pass on the tube side so the whole flow is in 8 tubes.. Flow goes front-to-back then turns in the back cover and flows back-to-front, then turns again in the front cover and flows front-to-back. If the blade is not in the heatex or the covers then check the two little elbows, one where it leaves the rear heatex cover and the other where the water enters the exhaust mixing elbow.. you need the water flow to cool the heat exchanger and exhaust. Happy hunting
