Robert Fischer
I have had to replace my impeller 2 times in the last month. I have a Universal M18 with an Oberdorfer 202M water pump. The water pump shaft is a 3/4 circle with a flat on one side which acts as a keyway. The impellers are spinning off this keyway, where the whole impeller insert is now rounded, so the shaft spins but not the impeller. This must be indicative of a larger problem with the raw water system. Please advise if posible. Thank you.
