I'm Surprised
Other Catalina 30 Tucson, AZ
that no one has commented on the thread titled "Don - white rock - weather helm". There is a ton of sail trim info there. It also shows how a mate can work against himself from a sail trim standpoint. You think you are taking corrective action but one step is cancelling out the other. Also, the chart is invaluable in that it tells you what controls to push or pull to adjust draft depth, draft position, twist and angle of attack.
Apr 3, 2005
40
Hunter 34 North Hero Marina, Vermont
Don, I searched for it but couldn't
find it. please post the link. Thanks George
Apr 3, 2005
40
Dec 2, 2003
480
Catalina C-320 Washington, NC
Click on Don's name at the left here.
That will show his posts, the one he is referring to is on 5/10. Don, the "chart" didn't show up, just a list.
Dec 2, 2003
480
Dan
I didn't get it
But I couldn't find the chart. I'm sure it would have made perfect sense with the chart.
Dan
I didn't get it
Quick Reference Chart
Go to the thread titled "Don - White Rock - Weather Helm" and my second response gives you the mainsail sail trim controls used to adjust draft depth, draft position, twist and angle of attack. The lister named Don had a heeling problem and he outlined the adjustments he was making to correct the problem. Unfortunately, he was using the wrong controls to get the effect he desired.
