So hopefully I explain this correctly. My battery switch (off/1/2/both) 1 position starting battery, 2 house, is connected correctly and operates properly. It's the ignition switch that has me perplexed. I installed a new ignition and wired it was it was before buying the boat. When I get to the boat turn battery to 1, the oil pressure alarm goes off (very loud) whether I turn the ignition switch on or not, actually you can start to boat with no key needed at all. Once engine is started and oil pressure builds alarm goes off as expected. My question is.....why isn't the ignition switch controlling the starting procedure. As its setup now the ignition when "turned to on position" only controls power to gauges. I know it has to do with how it's connected on the back of the ignition switch and to the starter I assume?? I just can't seem to figure it out.
The most annoying part is the loud alarm before I get engine started and when I turn engine off and have to race down to battery selector switch.
