Ignition Switch Replacement
Rich Brown
I have a '78 Hunter 33. The helm station ingition switch has become unreliable, causing me to have to go down below to crank the engine from inside the cabin. I would like to replace the key switch. Should any NAPA store have this item, or is there something special about the switch that would require me to go somewhere else?
Bryan C.
Get it from a Yanmar dealer
They are not expensive My local Yanmar dealer, Mike Valdez of Mavex (in Miami, 305-436-1860, can send you the part you need. If you use a Napa or other type of switch, make sure it is SS or it will rust fast.
