Ignition Panel Toggle
H
Howrd Franklin
Hunter Owners: I am a new owner. There is a toggle on the diesel ignition panel. It has a down and an up position. In addition, it toggles up higher past the top position but springs down to the "up" position. What is this switch for? Thanks, Howard
Ray
SWitch
This switch will illuminate the panel in the down position if the bulb is good. In the uppermost it will test the alarm then spring back, which is normal. The middle is normal position.
