Ignition Beeping Hunter 50cc
Jun 22, 2020
3
Hunter 50cc Whitefish, MT
My 2009 Hunter 50cc has a constant low volume beeping once is it started. I have traced it to one of the 3 inputs on the siren. It is the larger red wire that goes from the siren to the relay. The relay also lights the Engine Light. Does anyone have a schematic for the ignition switch and relays? I tried the 49 schematic but it doesn't have the same wiring. There are two relays, one for the high water test and switch. I have it figured out. I need details on the other relay and the 3 wires attached to the siren. Any help would be appreciated.
