Idling Diesel Engine
A
Amir
Hello, I have a H336. I have been told that it is not advisable to idle the engine for extended time period. I saw some evidence of it this past weekend when I was on a mooring and kept starting the engine every 2 hours for 10 mins to re-charge the batteries. The next day when I was motoring, I saw white / gray smoke from the exhaust. Never seen it before. Any thought on this would be very helpful.
K
Karl
idle speed
Diesels are best under load because extended idle causes carbon build up in the exhaust elbow. It's best to run it under load for about and hour at 2000 rpm. Also, if you have to recharge your battery every two hours you need a larger battery bank (ie...Battery capacity). Try adding an additional battery or a larger battery.
rfrye1
Jun 15, 2004
589
Hunter H376 San Diego
I've been told that.....
if you need to idle for longer periods its better to idle at 12-1500 RPM. Espescially when charging batteries.The higher rpm will allow the altenator to charge faster.
Jul 17, 2005
586
Hunter 37.5 Bainbridge Island - West of Seattle
Under load is the way to go
We bought the boat in 1992, and when it was time for the 1st service, I got the local Yanmar mechanic to work on it, and I video taped everything, including having him explain to me all the details on this specific Yanmar model, and showed me how to do some of the other less frequently needed maintenance tasks. He was paid by the hour, so that was money well spent. When you need to idle the engine for an extended period, you should do it at around 1200-1500 rpm. As for the need to charge the batteries every 2 hours, then you need more batteries. Do you have the factory installed single group 24, or did you add more. The #24 is fine as a engine starter battery, but if you need to have battery power while anchored, go with a couple of group 27s for a separate house bank, or at least 2 group 24s in a separate house bank. To do it right, you will need more, but 2 group 27s or 24s should be ok. You can charge them maybe twice a day. Even though the battery's top cover says deep cycle, you still shouldn't run it down real low. That will kill them. If you are running a fridge with the batteries, then it is going to go down real fast, and also, fridge under battery power doesn't get really that cold anyway. Ice cubes will melt. You need to run the fridge with your engine going.
Dec 2, 2003
4,245
- - Seabeck WA
Amir, I try not to say this to people, but,
Check the archives. This is a HUGE subject. And there are many good books out there. As the other guys said, you need more capacity.
A
Amir
Engine Idling
Thank you all for your responses. This certainly helps. I have 2 batteries. I use one for the house and the other for starting the engine.
