Identifying bottom paint
Nov 24, 2012
586
Purchased a used boat that was bottom painted. The dealer thought it was VC17. Does anyone know a way to identify a bottom paint (it is a hard paint not ablative). I understand one of the problems with VC 17 is that you cannot use a different paint over it
Feb 26, 2011
1,440
Achilles SD-130 Alameda, CA
Point of clarification- you cannot use a non-vinyl paint over it. Other vinyl paints are compatible.
1,096
CS 30 Toronto
What's wrong with staying with VC17?
Are you sailing in water not suitable for VC17?
We used it for 8 years. Easy to put on, very fast and no build up.
Last about 3 summer seasons.
higgs
Aug 24, 2005
3,704
Nassau 34 Olcott, NY
Sometimes it is tough to identify the bottom paint the po used. VC will be smooth with a greyish color. It will also easily sand off so check a small area. If you are in cold water, stay with it as it is very low maintenance and will last two years or more with a touch up.
Nov 24, 2012
586
This is for a small powerboat that I tow and keep in the water in the Florida Keys. This year I had lots of barnacles after two months so I want to better protect the bottom. VC 17 is a fairly common bottom paint where I sail on the Great Lakes but then our worst problem is slime/algae and not barnacles.
Jun 21, 2009
119
Catalina 30 Mk 1, #3335 Midland, Ontario
I found that a quick phone call to Interlux answered most of my questions. They were extremely helpful. Take a picture and forward it to them via e-mail as well as the characteristics, will any of it rub off when you press your palm across the surface for instance, how easy does it sand, does it flake off in large chunks...
There is a bottom paint that will coat over any and all existing paints but it does leave a buildup, not preferable if speed is required. I sand-blasted everything off last year and rebuilt mine from scratch, Interprotect 2000 through to VC17 (Fresh-water sailor)
Good luck.
DougM
Jul 24, 2005
2,242
Beneteau 323 Manistee, MI
A quick way to tell if it's VC or a similar Petit product is to take a rag dampened with alcohol and wipe a spot. The spot will have a copper shine. It's great bottom paint in fresh water, useless in saltwater. More than likely, the bottom paint will have to be stripped or media blasted before changing paint.
When investigating a replacement, remember that many bottom paints are not formulated for boats that are stored on trailers. They lose their effectiveness if they are out of the water for any length of time. In addition, ablatives will scuff off as the bottom is dragged across trailer bunks and rollers.
