Identification labels clutches /line stoppers C310
Clydo
May 28, 2013
368
Catalina C310 SF Bay/Delta
ID labels on my clutches are fading away. Anyone know where to get replacements
Catalina factory? Thanks for any replies.
Clyde Thorington
C310 # 245
I LEAN TOO
San Jose, CA
I have been using a P-Touch label maker on the boat. It's a pretty simple process to print new labels when things begin to fade. The problem I foresee will be the glue to attach the label to a fixture exposed to the elements.
The commercial purchased labels have lasted on containers and electrical wiring in the boat.
Joe
Jun 1, 2004
8,271
If you're having trouble finding element proof labels, rather than fuss with it, try alternative methods to ID the clutch. Such as small sign in front attached to the deck. I realize that's not a great description of what I have mind, but bear with me, I know what I mean... just cant say it... heh, heh. Anyway, I prefer the color code method. I've never had labels on any of my clutches or cleats. I have always referred to the color of the line. Just in case the crew member can't read. (but what if they're color blind, you say) yeah, well, I've only used the red line for port, green line for starboard deal for my two jib halyards... just so the foredeck guy can yell "GREEN!" or "RED!" to the winch operator in the cockpit. Works in theory, but rarely used... Since the boat isn't that big and you can see everything he's doing.
But the real reason color coding works well is that there's no translation needed. The skipper simply tells the guest to pull or release the red, blue, black, green, yellow, white(ugh) etc. line. If you say release the halyard, the guest's first comment will be "which one?"
:cool:
May 7, 2012
1,588
Hunter e33 Maple Bay, BC
John there is a P-Touch laminated tape that I have found to be very durable as it is affixed to a clean flat surface. The line is called TZe and the tape comes in various colours and widths. I redid the 8 clutches on my cabin top and the lablels have stood up very well over time. Here is a link that will help in choosing the correct cassette model no.
Brother P-Touch TZe Label Tape
Of course you will need to bum, borrow or buy a P-Touch label maker.
  • Helpful
Thanks HB. I have the label maker. I need to keep adding batteries. The tape looks good. I'll get a role and test it out.
