Ideas for an Environmentally Friendly Boat Restoration.
Peter
Apr 26, 2016
271
Macgregor 26M ca
- Water-based epoxy/copper bottom coating, 10 year lifespan.
- Water-based WR-LPU topside and deck paint, no VOC's.
- Sustainably harvested hardwood interior joinery, finished with water- based varnish or paint.
- Electric propulsion.
- Composting head.
OK, that's a quick list. Any other ideas out there?
Peter
#1331 'Sin Tacha'
Sep 24, 2008
346
Cotton sails instead of Dacron
Manila lines instead of synthetics
Forget the fiberglass - carvel planked with cotton caulking.
Wooden mast of course!
Why go halfway?
Aug 31, 2010
11
tylercraft tylercraft 26 sf bay area sonoma county
Well folks, we got here a bit of smarty. sarcastic comments for our friend asking about eco restorations? Is this community support or what?
As an environmentalist and a vega 27 owner with limited monies to spend on my boat and our other boat , I am at times on both sides of the fence on bottom paint issues. May the eco option be made affordable soon before all restrictions on copper based paint and our own being able to do our bottom paint jobs are selves are made illegal. San Diego I believe already is outlawing do it yourself bottom painting . As to ballast, rocks are a poor idea, unless your building a cave man yacht- on a ship wrecked island situation with just your leatherman multi tool . Eco options? Nature's head composting toilets are good, though do not fully compost the waste due to their design. Sunmar ecolet mobile toilets work better . For decks repainting if the gelcoat is worn, a product well proven that is easy to apply , holds up well, is eco friendly is water based Kiwi Grip non skid coating. Svedsens Marine in Alameda and elsewhere sells it. I will be using it. WInd power works for battery charging along with solar panels. As to electric motor , a great option for repowering, once the batteries come down in price and up in efficiency and are less in weight, [perhaps in 2 - 3 years as the industry advances rapidly as it is.
ANyway fair sailing and sharing helpfull information in our community here. Ecoearthyacht
Oct 31, 2019
303
I repowered a few years ago and did some serious calculations about going
to electric power. I was going to use currently available AGM batteries,
well I did think seriously about Trojan 6-volt. Anyway, weight of the
batteries wasn't a problem. Since I was removing almost 400 pounds of
diesel engine and transmission, plus the fuel tank (I carry 13 gallons),
the carrying capacity of the Vega as designed would allow quite a few
batteries -- probably about as much space as was available in the existing
engine room. The electric motors aren't all that heavy, but it would take
some design work to mount it properly. Then one has to have the controller
and charger and all the other stuff.
Finally, I figured that my cruising distance would be about 40, maybe 50
miles. OK if one only day sails or goes from marina to marina, but when
cruising that isn't practical. When sailed Mexico and crossed the Pacific
in my big boat I did have wind generator and solar panels. Neither gave me
enough juice to keep up with my electronics (OK, I admit I did have
refrigeration -- but no AC!!!).
Finally, the best way I found to generate power was a towing generator.
They are easy to build and I was able to generate 7 Amp/Hours 24/7. 160
Amps was a lot of power everyday and I lost only a fraction of a knot. I am
starting to build another towing generator, but it is now difficult to find
the appropriate DC motor to use as the generator for some reason. I've been
thinking of a really small alternator of some sort, maybe off a motor
cycle, but haven't researched it enough to really know if it would work.
Finally there is a group on Yahoo for Electricboats that is similar to our
Vega group. Most of these are small power boats, but it is interesting and
technology is technology:
(You probably have to go to Yahoo and join as I doubt you can just take
the link over to it).Chris
