Ideal Prop for 36 mkII??
Jun 26, 2015
17
Catalina 36 MK II Burred Civic Marina
I’ve got a 2006 Catalina 36 MKII which has a folding prop, on the smaller side. I get about 5.5knots under motor which isn’t cutting it for me. Can anyone recommend the ideal prop size and model for my boat? I would love to be averaging 8 knots under motor.
Thanks in advance.
jviss
Feb 5, 2004
7,090
Tartan 3800 20 Westport, MA
8 kt. under power in a C36? Sounds unrealistic to me.
LWL = 30.25'
Hull speed is 7.37 (HS = 1.34 x √LWL)
Likes: Parsons
May 20, 2016
3,015
I agree with @jviss 7.5 is about it. I cruise at 6.5kts, but you have a bigger engine that I do. If you want to maximize thrust over a wide range of conditions look at the autoprop.
Jul 12, 2011
1,165
Leopard 40 Jupiter, Florida
I replaced the 'optional' fixed 3-blade 15" x 9 degree with a feathering MaxProp 15" x 9 degree, as recommended by MaxProp, and am very happy with the performance. I believe the 'standard' on a C36II was a 2-blade 15" x 10 degree, which some hated. I can motor at about 7 kts, but, like Leslie, chose a more sedate 6-ish at about 2,000 rpm. It's the sweet spot between time, fuel economy, and shaking up the crew.
As I'm sure you've heard before here, everything is a compromise. In this case between cost, motoring speed, and sailing efficiency. Folding props are great for sailing, particularly in lighter air, but generally suck on the motoring front and cost a bomb. I chose a feathering prop (and paid for it) because it hit the sweet spot for lighter air sailing and motoring efficiency. Fixed props are better for motoring (except in reverse where I think my feathering prop wins), but is like dragging a gallon bucket behind your boat. None of the efficiency lost matters if you have enough wind (over 15?) because you have enough power to burn and you're limited by hull-speed. It's in the lower wind situation where folding props come into their own. Google "feathering propeller test" and you'll have an afternoon of reading pleasure.
Likes: sashaproctor
jviss
Feb 5, 2004
7,090
That's not "degree," it's pitch, the distance the propeller will move in one revolution in the absence of slip. So, 15" diameter, 9" pitch.
Likes: Parsons
jviss
Feb 5, 2004
7,090
MaxProp 15" x 9
That's what I have, but the pitch is adjustable, and I confess I don't know how mine is set. It's an awesome prop, with greatly improved performance backing. But, it's expensive, around $3,000, not including installation and set-up.
Feb 21, 2013
4,638
Hunter 46 Point Richmond, CA
With a 3-bladed fixed Michigan prop on my previous Hunter 31 and 386 and now Hunter 46 I am able to achieve hull speed.
