If someone has seen this before please let me know where I can go on the net to see it.
The green pole is a roller furler.
The blue ring is a halyard sheeve.
The orange ring is where the rope attaches that goes through the leading edge of the storm jib.
Here is how it would work. There would be a halyard already on the blue ring. You would roll the roller furler all the way up and secure it. Then you would hook the rope near the tack of the storm sail to the orange ring. Then you would attach the other end of the rope near the head of the storm jib to the halyard going through the sheeve at the blue ring. Then you would hoist your storm jib with a winch on the mast or have the halyard run through a turning block and back to the cockpit.
It could be all hooked up in a bag on the deck and the halyard ran down the mast to stay out of the way of the roller furler jib. Then all you would have to do is rollup the furler and hoist the storm jib with out leaving the cockpit.
This is a storm jib for a sloop. That sort of makes it look like a cutter. I got the idea after I saw that moonshine boat pic.
Please forgive my crude mock up.
