Ice Box Needs Insulating
Marcus Hart
The ice box on my h27 has no insulation. Was planning to insulate but the outboard and forward side are unaccessible. Has anyone conquered this problem? The isce box will not hold the cold very long without insulation. Any suggestions?
Jim McCue
foam board
Two thoughts- Go to Home Depot or similar store and buy some of those foam insulation board15"x3ft. Cut to size and use a thin layer of silicone smeared on board to adhere to walls of icebox. If inaccessable on back side, try those foam insulation cans with the accompanying "straw" to back fill the the area- the foam will expand to available area. Use razor knife to trim. Jim McCue
