Ice Box Drain??
51
- - Huntsville, AL
I sail an '85 Catalina 25. The ice box doesn't drain. Sliding my hand down the drain tube from the bottom of the ice box, I can feel the cold water in the hose all the way down to what might be the "drain hose shut-off valve". There is no cold water pass this "valve". Easy enough, just open the valve, right? Well, I can't get a good look at it, and there doesn't appear to be a handle that you can grab and turn. Is this a valve I'm unfamiliar with? Broken valve? Any advice would be appreciated! Ed
G
Gerry, GMJ Marine
Icebox drain
Ed, It could be a frozen check valve. These are one way valves that allow flow in one direction but self close if water tries to come back in.
C25 Association
Ed Go here: http://www.catalina25-250.org/forum/forum.asp?FORUM_ID=3 Then ask them. They do know everything about C25s. Stu
