Put a cork in it!
Nigel: I sail a 1989 33.5, Counterpoint. 1. I put a cork (from a nice Sauvignon Blanc) in the ice box drain and added a small bilge pump to remove the ice melt from the bottom of the box. (Water and the occasional spilled milk in the bilge offended the Admiral's sense of order.) To be honest, she was (is always) right. The ice box drain hose required some maintenance to keep it from providing negative aroma thearpy. And, it is easier to clean the ice box than the bilge. (I think that we repaced the cork with a tappered rubber plug that we found at the hardware.) 2. Two years ago, I installed a Johnson Split Back Stay adjuster. In the Defender catalogue a picture is on page 323. The folowing link will take you there: http://www.defenderus.com/cgi-bin/Web_store/web_store.cgi?cart_id=if you have Adobe Acrobat Reader. (West also carries the product.) I use a set up similar to the illustration pictured in Defender. On the 33.5 it is very easy to pull the top of the mast back and in heavy air when beating to windward, it helps to spill air at the top of the main. I pull on backstay tension after I have used the mainsheet, boomvang, outhaul and cunningham to flatten (and depower) the main. I also slide the traveler to leaward to spill air in the puffs. I am not sure that on the fractionally rigged 33.5 we get the added benefit of additional forestay tension. I fear that too much backstay tension may actually bend the mast forward at the headstay and allow the luff of the genoa to sag. I heavy conditions, I think that tightening the v-1's a couple of turns helps to minimize this. Ron (Captainronb@earthlink.net)
