PYI Props - HIGHLY Recommended
Dave,I'm guessing you have the yanmar 2GM20F. If so, you should check out the CDI composite prop (see related link below).It is specifically made for the 2GM20. I have one & it's fantastic. It's still a 2 blade so you don't get the drag of a 3 blade while sailing, but it has a variable pitch design that gives you a little more power than a regular 2 blade & it's better in reverse. I think a new one is under $300, so it won't break the bank.I have one on my Catalina 30 (LWL = 25', displacement = 10,500 lbs, beam = 10'11") and at 3k RPM's I get about 6 knots in flat calm water, but I still get decent headway in seas or a head wind.Anybody else have one of these? I'd be curious to know other people's opinions.Allen Schweitzers/v FalstaffC-30 Hull# 632
