you should be able to get the measurement from Hunter Marine, then simply replace the old ( usually wooden) mast step, with what ever material you wish. Its better to do with the mast off so that there is no extra compression on the deck plate, however , they have been done with the mast in place as well. You will have to remove some of the shrouds around the step, but that's easy enough to do. Good luck!!
