Topping Lift replacment
Since I have been up to the mast head more than once, and have dropped the mast while in the water, I thought I'd make a few comments. Regarding going up the mast, lighter weight people, who are not afraid of hights and know how to tie good knots can handle it. Use a climbing harness(aka repelling harness) attached to the main sheet. Using the jib sheet as a safety line is not a bad idea. How big a person is acceptable? Last time up, I weighed in at 225lbs. It makes the boat feel extra tippy, but its doable. I don't know how bad it might be for the rigging, except its been a few years and nothing has broken. The biggest problem is if the person tries to remove pin (clevis pin?) the topping lift ties to , there is a considerable risk of dropping it into the water. Dropping it is not overly difficult. I turn my boat stern in and put the mast crutch on the pintels to support the mast. Other than that, its not much different from lowering or raising the mast on a trailer without a hoist, just try not to rock the boat while raising or lowering it. Good manners suggest you also do not leave it projecting over the dock any longer than necessary, particularly if, like me, you are next to the gate leading to shore. Good luck. Jim Kolstoe, h23 Kara's Boo.
