I need some AC info
Margaritaville
Does anyone have an air conditioner installed under the aft seat of the dinette? If so I want to know how to run discharge ducts into the vee berth and if you have done it into the aft cabin and maybe the head. I am sure my installation is not very efficient. I like the unit installed there in the seat, but I would like to distribute the air through the boat better.
Margaritaville
Any H31 Owners?
I was hoping to get something from an owner of a 1983-87 H31. I really would like to make the air conditioner/heater more efficent. I am afraid the condensor will freeze up in its current configuration. Paul
John
Paul
This is where I have planned to install our a/c unit. What year is your 31? Ours is a 1987 with a u shaped dinette. I was going to build a plenum under the seating, and snake 4 inch flex duct up into the head, v berth, and through the galley into the aft sleeping area. I am going to use the head overboard discharge seacock as a pick up for condenser cooling water ( it is no longer set up for overboard discharge). I have not been to the boat in months due to back surgery, but in my mind it is all comming together. What size a/c unit do you have? Ours is 12,000btu. I e mailed Don @ Hunter, and he didn't see why it wouldnt work. A/C was not offered on our vintage Hunter 31's. Good luck, let me know what you come up with. John
SeaRanch
H31 Air Conditioner
I installed a 12,000 BTU Air Conditioner/Heater in my 1987 H31 in the hanging locker on the port side across from the head. I cut out the bottom of the closet, installed the water intake, filter,and pump below the water line. Bolted plastic 2x4's on the sides above the water line to set the unit on. Cut the outgoing water through the side of the boat below the bottom of the unit so seawater would drain out of the coils went the unit was off. The Marine Air distributor told me it was not wise to have the seawater out drain above the unit, because the seawater would stay in the coils and shorten their life. The diagram in the installation booklet showed the unit above the water line and the drain overboard below the unit. For supply air I rotated the fan output upward and cut a 6" hole in the top of the cabinet and built a box (plenum) to hold a register facing the open area of the cabin and a 4" tube out the back into the v-berth. Air flows freely through out the cabin. Attached the filter directly to the unit and cut a 12 x 12 out of door bottom to mount the return air register. Yes, I gave up a hanging locker, but I did not need complicated, long runs for seawater in or out, nor complicated, long runs of supply air hose. Works GREAT, neat and simple.
Margaritaville
I use the hanging closet
I opted for a larger AC unit. I have a 16.9K BTU. With the 90+ degrees I blow a lot more cool air in the boat. As far as water draining out of the unit I decided to let the water stay in the unit but to protect the coils I put a 1" chlorine tab in the strainer once a week, no mold or mildew in the coils and it kills barnacles. So there is no growth in the unit. The unit stainer and pump is below the waterline the unit does not have to work as hard.
