Joe M
I bought a 1983 H34 this past summer. The boat had the odor problem which I ignored so I could sail. Now I'm trying to get rid of the problem, but I need help.1) I cleaned the bildges at the shower, the large one by the setees, the small one just foward of the companionway steps where the keel bolt is, and in the engine area. The large one by the setees has three or four large holes that lead to the outer hull (I think). When I stick my finger in those holes there's still water in there. I got a small hand pump and got as much water out of those holes as I could but it's still wet in there. How do I get all the water out of the boat?2) I decided to change all the hoses and began by measuring them. To do this I needed to get to the holding tank itself. When I took apart the setee to be able to get at it I discovered it had a large patch on it. The patch ran along the seam that meets between the top and one of the sides. It appeared to be made of fiberglass and was loose to the touch. With very little effort it came off revealing that the seam had come apart where previously indicated. Is a new tank in order here?3) I also noticed that even though I fully pumped out the tank just before hauling there is about an inch or two of waste in the bottom. From reading other posts in this forum I know that this is not unusual because the fitting where the pumpout hose goes is about an inch off the bottom. Could this small amount of waste be causing the smell?Thanks for your help.
