Twelve days ago I replaced the old Perko fuel filter with a new Racor 230. The Racor is much larger than the old Perko. Prior to this I never had a problem with the engine quitting in the six years I owned the boat. The engine is a Yanmar 3GMF.The old Perko was lower than the tank and in direct line with the fuel pump on the engine (tank - Perko - fuel pump - secondary). The Racor is too large to fit in the same place. So for ease of maintainance I placed the Racor "higher" than both the fuel tank and the engine and therefore needed to "double" the length of the fuel line. Since then I can't keep the air out of the top of the Racor. The pump on the Racor is not strong enough to pull the fuel to the top when I bleed it so I must remove the bleed screw and fill the Racor to the top and then bleed it. Once the engine is turned off it seems the fuel drains out of the Racor back down the fuel lines to the level that's in the tank.Is the Racor too high? Would a small 12 volt pump on the engine side of the Racor be of any benefit? I'm thinking the small fuel pump that's on the engine is not strong enough to pull the fuel all the extra distance (I doubled the fuel line legnth at least) and up as high as the filter is located. Should the pressure or prime remain after I shut off the engine or is it gravity that's allowing the fuel to drain back down the lines (remember the Racor is higher than both the tank and the engine).Looking for advice. Thanks in advance.Joe Mullee
