Hello,
Well my water seperator had crud in the bottom of it, so I drained it. Then I started the motor and it ran great. I shut it off, and later I started it and it ran great again. Shut it off, and later started it again. It ran then died. I didn't refill the fuel sediment bowl (water seperator) so I'm thinking it "ran out of fuel." I cranked it until the bowl was full. I looked up "bleeding the fuel line on a small yanmar diesel" on youtube and it went through it pretty well. But I still can't get it started. There is something between the fuel filter and the water seperator. It has a lever on it, that a mechanic told me it's some type of an override pump. Question: Can that be used to bleed the system instead of turning the engine over with the key? Next. I unscrewed the 2 bleed screws on top of the fuel filter, but no fuel ever came out. The fuel filter was replaced last year. Question: Could it be there is water in there and should I drain and clean it? I undid one of the bleed lines from the injector, but no fuel came out of there either. Any tips?? Does this sound like it could be a fuel pump issue? I just bought the boat, but the motor has run like a champ, up until I drained the water seperator. That's what leads me to an air in the line problem. I've never owned a diesel motor, nor have I ever bleed the fuel lines. It's just hard for me to pay a mechanic $150 bucks to do it, because I know I'd slap myself and say, "I could have done that."
I'd appreciate the help.
Thanks,
Bob Sellie
"Sköl"
Thanks,
Bob Sellie
"Sköl"
