I need expert help. I am relatively mechanically inclined, but the problems I am experiencing have be baffled. I have an '85 Universal M25 with an Oberdorfer sea water pump.
Mon, Jun 3, 2013- After work, go out to my Catalina30 in the mooring field, start her up without incident and motor into a slip for some seasonal cleanup and the oberdorfer water pump impeller change at the 2 year mark. Changed impeller (impeller was worn, but no broken pieces), started the engine, checked for leaks (none found) and checked for water being pumped out aft of the boat (water was being pumped out).
Tue, Jun 4, 2013- Out to the boat for some cleanup, run the A/C with shore power. Try to start the engine...nothing! No clicking of the solenoid, no turning of the motor. all guages reading normal, both batteries test good. Both of them only 30 days old. Friend suggests I try a "hotwire" start to test the solenoid. I ran a line directly from the battery to the solenoid...and the engine starts without issue as if it were brand new. I shut it down and tried to do a normal start with the starter button and it starts again as if new. I started the engine normally and ran it 3 or 4 times thoughout the day. Never a problem, to include water pump working normally.
Wed, Jun 5, 2013- Out to the boat, tried a normal start....nothing. Tried the "hotwire" start, started right up. Shut it down, tried a normal start, started right up.....again, using normal start 3 or 4 times throughout a 3 hour period, started normally as if it were new. But now a new wrinkle: no water being pumped over board from the oberdorfer impeller.
Thurs, Jun 6, 2013- Out to the boat for some diagnostic work. Tried normal start: nothing. Tried "hotwire" start: motor turns, but now won't start. Tried normal start: motor turns, but won't start. Back to "hotwire" start: nothing. No clicking, no turning. Back to normal start: nothing! Both batteries still test good.
Anyone have any ideas? ...other than shooting it and putting it out of my misery. I've owned the boat for 5 years, never a problem like this.
