I'd go with starting batteries
I do mostly daysailing, and I normally motor for about 45 minutes each time out which seems to be plenty of time to recharge the battery power I expend during a normal day on the lake.Deep cycle batteries will last longer between charges but they also have a tendency to develop a "memory" if they are not heavily discharged between recharges causing them to not only have less starting current then the same size starting battery (that's normal) but lose their "deep cycle" capability. They are also more expensive then starting batteries.I have a hunter 30 and have 2 west marine starting batteries (the smallest size they sell I think, about $40 each), wired to a 1,2,off,both switch and west marine combiner connected between them.I normally just leave the battery switch on one battery and forget it. I play the radio all day, cabin and running lights in the evenings and at anchor at night, fire up the blender, the vaccuum cleaner and occasional tools off a 750 watt inverter.I've got a little cigarette lighter plug in digital voltmeter I got out of JC Whiney that reads voltage to the tenth of a volt and has High, Med and Low leds.When it gets to 11 volts I fire up the engine for awhile (it takes a long day of loud music and kids playing cards under cabin lights to need this) and if I forget and run that battery down to low to turn over the Yanmar, I just swap to the back-up battery which gets automatically recharged then switched out of the bank whenever the engine runs and stops by the combiner.
