I must hold the throttle or tie it off to maintain rpm
43
Catalina 34 New Orleans Marina
Our 91' Hunter 28 does not maintain cruising rpm. Due to vibration you have to hold the throttle in position or tie it off to maintain RPM.
Is there a friction adjust in the pedestal or in/near the engine compartment? If not how do I fix this problem?
Thanks in advance for the info.
Benny
Sep 27, 2008
1,149
Hunter 320 Tampa, FL
The friction ridges wear out after a few years. Some place friction restrictors on the cables and others use a wedge in between the lever and the binnacle. Make a small wedge out of cardboard and duct tape an use it until you find a more permanent solution. You can even attach a string to keep it handy.
Oct 29, 2005
2,362
My friend's H280 has same problem so I got him to put a small hose clamp (jubilee clip) to the throttle cable sleeve/shield. And it works. Careful to tighten the clamp till just about good enough friction for throttle to stay in place. Don't over tighten and collapse the sleeve/shield.
jtm
Jun 14, 2004
313
Hunter 28.5 Dataw Island, SC
You can also use a tennis ball- just cut a small hole in the top and bottom and slide it tight onto the throttle lever
Jun 4, 2004
1,087
Mainship Piliot 34 Punta Gorda
Yes, you can adjust the tension on the cable. Take you compass off and you should see the throttle cable connected to the pedesatal with little clamps. You shoudl be able to tighten it there. I think there is also an adjustment on the cable near the engine.
Jun 3, 2004
890
Hunter 34 Toronto, Ontario Canada
If you do use the Morse J style clamp, put it as near the cable head as posssible- that is as near the control as possible rather than near the engine. It is easier to get at to adjust if near the engine but works much better nearer the control- not as much cable flex I guess. I moved mine a couple of years ago and it works much better
IanJ
Nov 7, 2008
152
Hunter 31 Port Royal, CA
I keep a small rag on the binacle to wipe off instruments etc, and just slip it between lever and case when cruising under motor to hold still. Tidy and easy to take on/pull off
Scott
Sep 24, 1997
242
Hunter 31_83-87 Middle River, Md
Jammed a moist paper towel between the binacle and throtle for a few years and it worked great. Installed a new throtle cable, and "wa-la" works "greater."
Jun 2, 2004
80
Catalina 30TR Polk City, Iowa
As in an earlier post, remove the compass. As you stand facing the bow, look down on the shaft that exits to starboard and you whould see a bolt. It provides friction when tightened to the shaft. Tighten the bolt until you have sufficient pressure to hold it.
Nov 23, 2008
79
Hunter 29.5 Big Ridge Marina, Hixson, Tn
A bungie cord works, I used on throttle on my my Hunter 29.5. I set at 2700 rpm. Worked well.
Dec 23, 2009
43
Thanks to everyone for your ideas. I removed the compass from the binnacle and tightened the friction bolt. Problem solved.
