I just bought a Neptune 24, looking for help
Hooks
Oct 11, 2014
49
Neptune 24 Slidell, Louisiana
So I posted this thread to the Newport section b/c there isn't a Neptune section and google tells me the same people made both boats? I don't know. Just wanted to cross post it here to hopefully get some assistance.
http://forums.sbo.sailboatowners.com/showthread.php?t=167052
I just bought a Neptune 24 and Google says that it's built by Capital Yatch's but is very similar to the Newport line. So not sure if this is a place I can ask questions. If not can someone direct me to the proper section?
Bottom line is I paid $3000 for it and the guy is letting me put $1000 down and make $400 payments for 5 months. It's not the boat I wanted but it's the boat I can afford until I can find something more what I want. Going to try to live aboard but not sure if there's enough space. Only one way to find out
Issues I'm aware of that I need help with.
1) The entry way "door" is rotted wood. It needs replacing. Where can I find something that matches the specifications of this boat?
2) The cushions all need new covers. It's just foam wrapped in sheets right now. Where do I find some that will fit? Searching google for neptune sailboat isn't turning up much.
3) The wood counter around the sink is rotten and needs replacing. I guess I just take the wood out, bring it to home depot or something, and have them cut me something similar? I take it I need to put something on the wood to make sure it lasts?
4) He added a water pump to the kitchen faucet that kicks on automatically when the knob is turned but the faucet in the head is the hand pump kind and It's not working. What's step 1 in troubleshooting it?
5) It has a window unit rigged under the entry way but no heat. What's a good heater that will work in a small space that won't burn the boat down? Preferably something that will kick off when a certain temp is reached so I don't wake up in the middle of the night sweating?
6) It needs a good cleaning. What's a good cleaner that will work on the fiberglass well? Like I wanna go out there this weekend, and scrub down everything.
7) The bilge doesn't have a float switch and you have to manually connect it to the 1 battery on the boat. How hard is it to add a float switch?
8) I need a battery charger. What's a good recommended one that will make sure the battery is always at a full charge when I'm at the dock?
9) It only has an ice box and a sink. I have a mini fridge I can find a place for but need something to cook on. Any suggestions there? I have a propane grill but not sure if they will let me keep it at the dock. So I was thinking a cheap plug in the wall burner thing? I have a Microwave I can try and fit too but space isn't an asset on this boat.
10) There's a compass and maybe a depth finder. Any suggestions on something cheap that can help me navigate and at least see the wind speed and how fast I'm going? I'm just going to be around Lake Ponchartrain so I don't really need much.
11) I want a larger canopy to keep the sun off me. Where can I look to find that for this boat? I plan on spending a lot of time outside and it gets HOT in Louisiana so the more shade I have the better.
12) It doesn't have the large plug that is at the marina. The owner (who lives 2 slips over and is going to help me with a lot of this) said that the people that lived on it before he bought it had an adapter cable going to an extension cord and had that rigged in the boat to power the A/C, fridge, microwave, etc. He said I can make one of these for $10 at home depot. Any clue what he's talking about? Are there plans online? Is this safe?
13) I want to make the boat more of a live aboard. So I want to add some form of storage. What's out there? I don't need all the beds and couches so I planned on removing the foam from one side of the boat and putting the microwave and mini fridge and whatnot on it. Maybe I can rig some form of cabinet space above it? I don't know. I have a 47" TV I'm going to try and fit somewhere in there.
14) Any tips you guys can offer me on living in such a small space? I have a dodge caliber I bought to help with storage. I can fold the back seats down and put clothes and whatnot in cardboard boxes back there if need be. But really I had an 800 square foot apartment and occupied maybe 50 square feet? I don't need much.
I know there will be more questions. Sorry. There's so much I want to know and so much to do. I'm extremely excited and happy to finally have my own boat, even if it's tiny
Dec 7, 2012
515
Kittiwake 23, Irwin 43 .. Indianapolis / indianatown, fl
hello
and welcome to the family of sailboat owners
you can contact the admin section and ask for a Neptune category be added... I did that and they added the Kittiwake category for me... and come to find out there are several Kittiwake owners on the board here... congrats on the purchase... my 1st sailboat was a Mac25 I won in a church auction for $25.... my 2nd sailboat is a 1967 Kittiwake 23ft sailboat I traded a flat screen HD 40" tv for.... my 1971 Morgan 35ft sailboat I paid less than blue book for....
QUESTION : if it isn't the boat you wanted, why are you paying all that for it ????
answer 1; I built the doors on my Kittiwake sailboat ... I used Mahagony and lexan windows.... I buiscut joined the door frame together, then attached the lexan windows... I bought lift off hinges and attached them to the entry to the cabin.... the doors swing out and can be lifted off the hinges to stow below when sailing...
Anser 2 ; upholstery shop... take in the old ones for them to use as patterns, or learn to sew...
Answer 3; use the old counter as a pattern and cut it yourself, then cover with atleast 3 layers of marine grade varnish... I use a clear wood sealer before I varnish any wood on my boats....
Answer 4; start by tracking back the water lines from the head faucet... they might not be hooked up... you do not mix a pump faucet and an automatic faucet... they do not work on the same pressure lines...I would replace the head sink faucet with a regular faucet and make sure it is hooked into the main line with the electric pump for water pressure....
Answer 5; get a floor model room heater that plugs in either 110ac or 12v dc... these all have a safety, should they tip over, they shut off automatically.... they also have a temp range auto switch on them too... I have one on my Morgan.... works great....
Answer 6; I like to get the wet wipes ... kills germs as I am cleaning... for the really tough stains, use bleach or fantastic....
Answer 7; simple to add the switch... 2 wire connect and mount the float switch....make sure you seal the wire ends from water, or it will corrode and stop working totally....
Answer 8; I got a 12v dc charger with the trickle charge auto setting on it.... this way all my batteries are topped off all the time and ready for use... also I have solar panels and controller that keep them topped off most of the time and the battery charger is not needed....
Answer 9; not sure on your layout, but get a camp stove to sit on the counter top on your galley area... if you get a counter top cover for your sink, you can set it there for cooking then store it away later when not needed... with the right attachments you can make a BBQ grill that attaches to your aft pulpit and you can cook from your cockpit....
Answer 10; do you have a cell phone ???? look for navigation, compass, wind, gps plotting apps for your smart phone.... I have them to use on my little boat... on my big boat I use the garmin 176c gps/chatplotter....
Answer 11; do you plan to use the sun shade while sailing?... or just when docked or anchoring?... if only going to use it during anchoring or at dock, I would suggest a boom tent... easy to make, easy to use, easy to store.... if you plan to use it while sailing, then a Bimini will be in order... you can find all kinds of Bimini's on Ebay... but you need to know how wide and how high you need it to be....
Answer 12; it sounds like they just ran a set of extension cords to power whatever they needed.... it is ok, but not totally safe.... what you need is a shore power hookup installed on the side of your cabin.... a cable can then be plugged into you boat and ran to shore power.... inside the boat, the power lines are ran like in your home to a set of perminant recepticles for you to plug into to use your AC appliances.... My boats are set up for only 12V systems.... everything I have on board my boats are 12V dc powered....my big boat has a AC power inverter to switch everything over to 12V....
Answer 13; storage is already built into your boat... under the bed, under the settee, under the lounge... anything can be done to add more storage to your boat....WOW, such a big TV for a little boat.... I have a 37in. in my big boat and I think it is almost to big for the cabin...
Answer 14; remember simple living is an art in itself... living on the boat will help to keep down your expenses too.... learn to do most of the work required on your boat yourself.... marinas charge big fees to work on boats....learn where the local hardware, home improvement and marine store are....
the forum here is full of answers, learn to look up old posts about what you are trying to do.... there is a world of knowledge here to learn.... remember, there is only one dumb question, and it is the one you didn't ask... seek out the knowledge, friendship, and commeradery here....
I have learned a lot here, met some great people, and found new friends....
sincerely
Jess
Hooks
Oct 11, 2014
49
Thanks, I'll ping them :)
It's what I can afford right now and the owner is working with me on financing it for a few months while I pay it off. He's also a good person and is going to help me with working on it and going to show me how to sail her good :) So it's all a package deal. I'll save and fix my credit and the next boat I get will be more along the lines of what I really want. And then I can resell this one or keep it around I don't know yet.
Any online tutorials for something like this? Sounds awesome.
I don't have any of the old covers. It's just bare foam right now. What's the cheapest option? I think it just looks super ghetto right now.
Thanks :) Will do that. Have a buddy with cutting tools I can borrow.
Hmm maybe he disconnected it then and doesn't remember. It isn't screwed down so maybe it's just not hooked up. I don't need it but figured it'd be cool to fix.
Well I can't really do much over 12v DC. It's got a battery but I have a spare I can bring on board. No charger for it though. Was looking for something solar maybe or something that plugs into an extension cord? How long does a battery hold a charge for at sea?
Danke
Do you have to drill in the boat? Nervous about that. Trying to picture how it mounts.
Ahh cool. Answers my other question then. Any recommendation on brand and size of solar panels? How pricey is it?
That sounds cool. :)
It's a windows phone but I do have an iPad 2. Maybe find a waterproof case and mount for it? Hmmm
Probably both sailing and docked. I'll look into the boom tent if it's easy/cheap for now. But man it gets 100º+ around here so every bit of protection from the sun helps.
Yea that's what they did. There's no recepticles at all. There's a battery in the boat under the steps hooked up to the water pump, running lights, etc. There's a bilge pump with the wires floating in the bilge water that you connect to the battery to drain it. There's a window unit with it's power cable just dangling and that's pretty much it as far as electronics go. I kind of wanted my first boat to be basic so I'm not upset about this at all. Just not sure what all is needed to be safe.
Yea I'm thinking I need to sell the TV or trade it. Gonna bring a tape measure and see how much room I'll need and where I can put it.
sincerely
Jess
Thanks :) Can't wait to get started. Sorry for the short reply earlier, barely slept last night so I was a little out of it.
Dec 7, 2012
515
hello
check out a woodworking site on technics about building doors, or consult with a friend who knows about woodworking... maybe you can get him to build it for you....
check out your local area... maybe go to Jo Ann Fabrics and see if they have anyone who can sew them for you.... a little money and supplies and you will have new cushions....
I use 2 - 30 watt solar panels and a controller on my little boat... it keeps my 2 batteries fully charged... and I can run my lights all night... to run other things I need another back up battery at night... the battery charge will depend on how many electrical items you are using during the night.....during the day the solar panels will take some of the use for the items....
the switch is a rocker style... the base can be glued into place with a water resistant glue...
I found my solar panels for $56 each, the controller for $15, and the spare connectors for $4...
yes... ipad2 is good with waterproof case... to mount it I would use Velcro on the waterproof case and a place on your boat in the cockpit where you can see it
I use the boom tent on my little boat and the Bimini on the big boat.... I wear a big rimmed Australian style hat when sailing and my wife brings her umbrella to use for shade...
I will find some pictures for you about some of the items we have talked about.... I hope these pics help...
sincerely
Jess
2,500
Oday 192 Lake Nockamixon
sailrite.com has many video tutorials on how to sew cushions.
Hatch drop boards can be as simple as plywood. Make sure to cut the joints between boards at an angle outwards and downwards, so water dripping down doesn't drip inside the hatch boards. Varnish them up, or paint them if you don't feel like learning all about 10-12 coats of varnish :D
There are tons of blogs and web sites of people on the internet who have modified the interiors of their boats to create additional storage, sliding galleys, or even stuff as simple as a moveable galley box that holds dinnerware and single burner stoves.
The Left Coast Dart people have built a very simply A/C deck plate system: http://www.leftcoast.biz/iWeb/Left_Coast/AC_deck_plate.html However, I would not add ANY A/C system to a boat unless the deck plug uses a Smart Plug. The old standard is ****, and you can learn why here: http://www.pbase.com/mainecruising/installing_a_smart_plug
You have a lot of stuff on your list, and it sounds like you have A LOT of learning to do. Just start googling things on your list, and read up on how others have solved that problem. There are plenty of people who have done this before you. You have to learn how to be a Mr. Fixit unless you want to spend LOTS of money to have others do it for you...
Nov 9, 2012
2,500
By the way, the asterisks in my previous post were a word that started with S and ended with T, and I mince no words about my opinion after reading Maine Sail's website.
Jul 13, 2010
1,100
Precision 23 Perry Hall,Baltimore County
You have a long list, sorta like mine was, many items. I found that keeping it on paper(maybe on a clipboard) was helpful. drawing a line through that item "done!" can be more satisfying than a cold drink at sunset!.
Hooks
Oct 11, 2014
49
So I had some time Saturday and Monday to work on her. There's so much to do. And everything is so expensive. Now I see why they say a boat is a hole in the water you throw money into. But I am up for the challenge. Still need to set up a blog to put this stuff but hopefully this thread can be used for that.
More pics: http://s515.photobucket.com/user/load81/library/Neptune 24/11-8-2014
Progress:
All trash is off the boat
Found all 3 lights on the boat had bad switches so for now I bypassed the switches and the breaker for cabin lights just toggles all 3 lights. Not sure if I'll fix it the right way yet but at least I can work on the boat now. This took much longer than it should as I was convinced it was a problem with the breaker seeing how all 3 were out with good bulbs.
Counter in galley removed and in the back of my car atm. This took way longer than it should have but there were screws I couldn't get to and I was trying not to rip it up too much so I can make sure what I build is as similar as it can be. Also the sink was a PITA to figure out but now it all makes sense and I just need to find wood and make it look nice and seal it good.
Did a little troubleshooting with the running lights. Seems like the bulb is just burned out but the guy siliconed the bulb in so it's going to require more than just replacing the bulb. I didn't check the front light but assume it's just out as well.
Took all kinds of measurements. My 27" TV will fit on the wall above the table just need a wall mount. My fridge however isn't going to fit. It's too tall. I researched putting it on it's side and rotating the compressor and whatnot. Yea not gonna work on that fridge. New plan is buy a chest type deep freezer and add a temperature switch so I can keep it as a fridge and then just use it as a freezer when I need one.
Got all the cleaning supplies I could think of and borrowed a wet/dry vac so next step is going to be cleaning and scrubbing until I get more funds for cushions.
Wow when I do a progress list it doesn't seem like I did much for as much time as I spent on the boat lol.
New Questions:
Toilet doesn't seem to be sucking in sea water. I didn't spend too much time looking at it but there were 3 valves under a bench I took a picture of. Not sure in what configuration they need to be and the black one don't even turn all the way it hits up against the other valve.
Two wires are sticking out the ceiling for what I'm assuming was a light that got taken out. He didn't leave any slack in the wire its cut right at the hole. Any sailor tricks out there to tap into the wire to make it longer to test it and possibly add a light back?
Any tips for cleaning up an oil spill in one of the outdoor storage areas?
Any tips for restoring the teak on the outside? I read to try to just clean it first and see how it looks after but says I might need chemicals and such and then I have to seal it and maintain it every month. I do have access to a pressure washer if that would help but I imagine a lot of water would end up in the cabin.
Regarding the siliconed in running light, I'm guessing the proper way to fix that is remove the light/wire and buy something that will actually just tap into the wire and mount to pre-existing holes?
As you can see in the pictures one of the stanchions needs repair. What's the best way to tackle this? I'm guessing some sort of epoxy?
I need to fix the front hatch. Any ideas? Looks like the fiberglass is peeling on the inside and I really can't stand how ugly it looks. I was thinking lightly sand it and then paint it with marine grade paint? I was thinking of pressure washing the underside of the outdoor lids and then painting them with the same paint if that is doable.
I'm sorry for all the questions. Seems every time I get an answer for something there are a dozen new things I notice. I did buy that book about restoring an old boat but have not had time to read it. Maybe tonight as I can't be on the boat.
PS I named her "Drunken Soldier" after one of my favorite Dave Matthews songs. It also fits a little as I've been known to drink a bit of Gin. Need to find the best way to put the name on the boat and where to get it. Thinking maybe have someone do it professionally as it would probably be crooked if I did it and off center. I figure on the rear starboard side opposite of the engine?
Dec 7, 2012
515
hello
you are on your way to making it your baby... have fun with it...
are you sure the light switches are bad.... my switches have fuses in them... each switch has it's own independent fuse for what the load is set for....
it is always easier to put the new counter on, than it is to take off... you already know where everything goes, now that you removed it....
sea dog makes good navigation lights at a descent price.... you might be able to find the exact same model of lights that you already have.... if not, send me a picture of your lights, I have several sets of navigation lights extra here.... maybe we can work something out....
look at the fridge units that the truck drivers use... 12v and can sit upright like a fridge or set down like a cooler... can get them sometimes inexpensive... I have 2.... 1 for each boat....
the toilet should have 2 valves and hoses.... 1 for water intake, and the 2nd to flush out to see... some boats have a Y valve that can divert everything to a waste holding tank for later pump out...
if you cannot track them back, or get a reading for power from them... then I would suggest you attach 2 good wires to them and pull them back through until they are replaced with the new wires with extra length to work with...
try a degreaser like easy off oven cleaner....worked for me
teak issue... I replaced all my teak with Mohagany... I do not like the teak, too much work to keep looking nice... always working on it to make it look nice...
answer to your own question... yes... replace it, unless you can get all the silicone out of it... silicone was probably put into it to stop a water leak....if that is the case, you will want to replace the lights with something that doesn't leak....
if the stanchion is coming off the deck... remove it, fill in the holes with fiberglass epoxy resin, then drill new holes and add a backing plate to make it stronger... when you drill your 1st set of holes, drill them 2x the size you need... then fill them with fiberglass epoxy resin... then drill to the exact size you need for the bolt... then ;put silicon on the bolt and refasten your stanchion on... the reason you drill the hole 2x the size needed then fill with fiberglass epoxy resin, is this will prevent any water that might leak down the bolt to get inside the fiberglass and cause delamination or wood rot ...
the front hatch on my little boat was not painted and the raw fiberglass was seen... it was done this way back in the day to allow more light into the cabin... I painted over mine and attached a 30 watt solar panel ontop of it....painting the hatch covers are doable... one thing to remember, any time there is a difference in temp inside the boat vs the outside, condensation will occur on the bottom of the hatch cover.... use a good anti mold paint under them... another idea, is to cut out most of the hatch and replace it with a piece of clear plexiglass to allow light in....
asking question and getting answers are how we all learn new things from the old salts here on the forum... remember the only dumb question is the one you didn't ask, that will later get you into trouble...
great name.... I went to a sign maker and he made me vinyl letters for my name for my boat... he even had the font style I wanted too... my wife is Chinese and she names both our boats..... the Kittiwake 23' is "Xing Fu" = happy boat..... the Morgan 35' is "Kai Xin Yuan" = happy home... the letters are done in the Chinese font like from the old movies....she liked the style too
sincerely
Jess
Sumner
Jan 31, 2009
5,254
Congrats on the boat. Looks nice and something you can enjoy using and fixing up.
Looking at your pictures I see one thing you might want to consider changing.
I'd be leery of that PVC ball valve in that application. If it failed you might be sunk. I'd look into a proper bronze valve or other valve designed for a thru-hull. Not as cheap for sure but a lot safer. The same goes for the one that is top-left if it is brass I change that out also.
You talked about 110 from the marina into the boat and a charger also. The 110 and the charger can pose a possible problem to anyone that might be in the water near the boat, as in possibly killing them so you want to make sure you are using a marine charger and not a car charger and you also need to make sure the 110 wiring coming into the boat is proper to avoid any deadly situations. It is not as easy as house wiring or car wiring since you are mixing 110 volts and 12 volts and you have the boat in the water to factor in.
Maybe all of that is in order but if not look at these links and stay safe...
http://www.westmarine.com/WestAdvisor/Ten-Deadly-Conditions
http://www.westmarine.com/WestAdvisor/Marine-Grounding-Systems
http://qualitymarineservices.net/Neutral-Ground Bond, Exchange Article, 12-2005.pdf
Wiring correctly can be confusing so if confused please get help here or with someone there and the best on using, fixing and living on the boat,
Sumner
[FONT=Arial, sans-serif]============================
Our Endeavour 37
Our MacGregor 26-S Pages
Mac-Venture Links
[/FONT]
walt
Jun 1, 2007
3,556
What is the difference? Link?
Sumner
Jan 31, 2009
5,254
The marine charger if built to ABYC / UL 1236 standards should have good AC/DC isolation and reverse polarity protection in case the shore power has a problem in that area.
Maine Sail has a good review here and talks about the differences...
http://www.pbase.com/mainecruising/installing_a_marine_battery_charger
... and you can find the same info other places.
I've used a car battery charger at home before I put solar on the boat and I don't see a problem with that with the boat out of the water. The problem can be a "possible" safety one with the boat in the water if someone is near the boat in the water.
Not a huge difference in price so why not get the better one and they probably also have a better charging algorithm vs. a cheaper car one,
Sumner
Our Endeavour 37
Mac-Venture Links
[/FONT]
walt
Jun 1, 2007
3,556
Ok.. this was something you read on the internet - but from Maine sail which is generally a good source. I think that more likely means don’t buy a POS charger.. (such as an old and obsolete design transformer style charger).
FYI, I would be surprised that you can buy a non UL battery charger at all. Its insurance underwriting, protects anyone who sells the product. UL 1236 covers about any battery charger you can plug into AC. Home, car, marine. Pretty much every single item that you can plug into AC gets that high voltage test. We do it on consumer electronics but at an even higher voltage 2120 volts DC (called Hipot test)
If you correctly hook up a marine AC and DC system, it will be automatically protected from some of the bad things that can happen with a battery charger - like a fault where the AC input gets put on the charger chassis.
UL 1236 scope is below:
Battery Chargers for Charging Engine-Starter Batteries
UL 1236
1 Scope
1.1 These requirements cover battery chargers rated 600 volts or less and intended for household or commercial use to charge lead-acid engine-starter and other starting, lighting, and ignition (SLI) type batteries, in accordance with the National Electrical Code, NFPA 70. The requirements also cover a battery charger intended to be permanently installed on a boat.
walt
Jun 1, 2007
3,556
I have had to deal with UL a fair amount, I think they are best at extracting money out of manufactures. Must have a lot of lawyers there.
However.. if you want to sell something to the public in the US.. you almost always need to have the UL rating. Simply, it protects you from a lawsuit.
But.. the UL specified high voltage tests we do on consumer electronics (and it is done on 100% of everything that plugs into AC) does insure that when you plug the unit in, it will not have high voltage on the chassis. If the cord has an earth ground, the UL test also makes absolutely sure that the green earth wire has a very low impedance connection to the chassis of the device.
Hooks
Oct 11, 2014
49
You guys are talking way over my head. I'll have to research it. The marina I'm moving the boat to has both the 220/30 hookup and two 110/15 plugs next to it. So once I move the boat I'll just have two heavy duty extension cords going in the cabin.
I just got done putting together a checklist for the boat. Let me know if there's anything I forgot lol
https://onedrive.live.com/redir?resid=FC34E17E28BA5143!7905&authkey=!AGNq65yGVCyY0u0&ithint=file,xls
So far I'm 13% done of the current list. Got my work cut out for me but hoping to knock out a large chunk this weekend.
