I.D.ing an old MacGregor
BobW
Jul 21, 2005
456
Hunter 31 San Pedro, Ca
Never seen anything like it. The most prominent feature was a raised fordeck aft of the v-berth. It also had a longer boom, with the mainsail sheet controlled from a v shaped pully system overhead (so there was no attatchment in front of the entrance to the cabin. It almost looked like it may have been something close to the m model...the aft end had no "compartment" in front of the motor, it only had a flat back end to it, but it only had an 8 hp motor, and seemed pretty old. Does anyone know of a mac like this?
L
Len
ID
My 25 M has a bit of a raised fordeck. the main sail sheet is controled behind you in the cockpit so there is no traveller in front of the compainionway and it has a topping lift on the main sail too. There is no well for the motor and the side windows are pink. There is no colouring of the Gel coat on the top deck. Center keel is swing made of steel although I understand there may be some out there that are called 25C ( center board ) If you can post a pic it may be helpful
richard
pink side windows confirm it!
This one had pink side windows too! Thanks for answering.
